Static Routes
Hi Guys this is a requirement that my teacher assigme, I can´t do it... is posible?
-L-1 and L-2 they must communicate via the ethernet  shared by "S-AR to Central as primary path, while the serial connection between R-1  and R-2 will be as a backup path to be inserted if the ethernet falls.
I try to use
ip route 0.0.0.0 0.0.0.0 fa0/1 3
ip route 0.0.0.0 0.0.0.0 s0/0/0 5
But I can´t comunicate because the packet can go out but it can´t come back. help me!
Tharak Abraham
Level 3
Level 3
Julio,
Your teacher told all of us not to help you with direct answers...-:)
You are almost there with the req.
1. Please check whether all directly connected links are pinging.
i.e connection btw L1 - R1, R1-R2 via serial, R1-R2 via S-AR and R2-L2
2. When pinging, if the packets are going out of R1 and not coming back dont you think that you are being unfair with the packets
transmitted back by L2 ?
3. Can you try the command "debug ip icmp" on R2 when pinging from L1 to L2 ?
Let us know if you solve it !!
Best Regards,
Tharak
