Creating port-channel subinterface on a 4510RE
not able to create subinterface on 4510r model switch
sub int on port channel
Charles Hill
Hey vasanthmanoharan,
It looks like the 4500 series switch does not support subinterfaces on layer 3 interfaces, if this is what you are attempting.
"A Catalyst 4500 series switch does not support subinterfaces or the encapsulation keyword on Layer 3 Fast Ethernet or Gigabit Ethernet interfaces."
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/37sg/configuration/guides/config/l3_int.html
Hope this helps,
Please rate helpful posts.
Thanks.
Charles Hill
Hope this helps,
Thanks.
