Creating port-channel subinterface on a 4510RE
wilfred malana
Just received a 4510RE w/ SUP7s which will start rolling out at the access layer in place of 6500 chassis. I ran into an issue creating port-channel interface with the 10GigE uplinks. Sitching the port-channel to L2 or L3 doesn't seem to make a difference.
Here's a snippet of sho ver..
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.01.01.SG RELEASE SOFTWARE (fc1)
Copyright   1986-2010 by Cisco Systems, Inc.
Compiled Tue 14-Dec-10 21:30 by prod_rel_team
License Information for 'WS-X45-SUP7-E'
    License Level: ipbase   Type: Permanent
    Next reboot license Level: ipbase
Is it a licensing issue?
10 Replies 10
Reza Sharifi
I am not sure what you mean by "
Sitching the port-channel to L2 or L3 doesn't seem to make a difference."
can you explain?
should not be a license issue
Sorry.
Sitching , I meant switching .... or I guess the better wording would be "making it"
Making the port-channel a "switchport" (L2) or "no switchport" (L3)
Can you post your config?
A layer-2 Etherchannel can be in an access mode or trunk mode.  A layer-3 Etherchannesl is a routed Etherchannel with IP address.
It's default config right now.
I can create interface port-channel 1 but when try to create interface port-channel 1.200  it fails. Like it doesn;t know how to deal with sub-interfaces.
ROC-RS4510RE-AU-E130(config)#interface port-channel 1 ?
ROC-RS4510RE-AU-E130(config)#interface port-channel 1.200
% Invalid input detected at '^' marker.
I have never seen a "sub-interface" port channel before.
I do this all the time on the 6500 platform w/sup32s and sup720s.  I appreciate your help.
Learn something new today.
  Normally you do not use subinterfaces on a trunk on  L3 etherchannels . Normally that is used for router on a stick scenarios on like ISR"s . You use vlans and SVI"s across a standard trunk setup for L3 etherchannels.  I don't believe it will work , if its rejecting the commands thats another indication it will not work.
int port-channel 1
switchport
switchport trunk native vlan X
switchport trunk allowed vlan x,x,x,x
switchport mode dynamic desirable
Hi I have same problem i am not able to create sub interface could any one help me on this.
- See more at: https://supportforums.cisco.com/discussion/11212321/creating-port-channel-subinterface-4510re#sthash.xiWPfeSq.dpuf
wilfred malana
That's what I had do to. Just attempting tk standardized configs on all my access layer switches.
Thanks a lot for the tips.
