Cross bundling from 2960xr switches to server(no VSS, no Stackwise)
shabeerahamed80
I have 2 catalyst 2960xr switch which is inter-connected by 2 interfaces and bundled each other(normal etherchannel). Now I have a requirement to connect a standalone server with 2 NIC which is to be connected in each of the switches and will be teamed in server side.
How can I achieve cross bundling as my switches are independent(no Etherchannel Domain) to each other.? Can I use LACP teaming in server side..? What could be the appropriate solution to accomplish the redundancy if any one of the switch fails..?
marce1000
 - Use for instance, this example for a  windows-based host :
             https://docs.microsoft.com/en-us/windows-server/networking/technologies/nic-teaming/nic-teaming-settings
 M.
@marce1000 Thanks for sharing the above document as it describes how to configure it in server side but i need a solution to configure in switch side....
More suggestions would be much appreciated...!
 - Here's an example thread on the matter :
            https://community.cisco.com/t5/switching/can-we-connect-single-server-to-the-multiple-switches/td-p/2504446
 M.
