cross connect between c3750 and c4500
Umit AYDINLI
hi,
I have c3750 and c4500 switches. I want to crossconnect 2 vlan so I need connection 2 diffent vlans. Can you provide example configrations?
Whatever other case, I want to crosconnect between c7200 and c3750 2 diffrent vlan. It's posible?
Could you clarify if you want to use the 4500 and 3750 as just a layer 2 switches with the 7200 as the router?
I mean, I have connection for 2 isp on the c3750g switch. isp 1 vlan id 256  isp 2 vlan id 710
I want to connect between vlan 256 and vlan 710. Because I have diffrent location for same subnet and diffrent isp.
I have cisco 3750g, cisco 4500 and cisco 7206vxr devices.
I wonder how this would work as there will be a lot of IP address conflict if you do have both these locations transparent to each other. The best way would be to have different IP subnets for the two sites though?
