CRWS for cisco 3500 series switch
srikanth ath
Level 4
Level 4
hello Experts,
I'm bit confused whether the Cisco model 3500 (cisco WS-C3548-XL ) has the CRWS tool which provides GUI interface for configuring the switch. The reason i ask is the Security team have found the vulnerability in this device and suggested me to upgrade the current Crws version to CRWS 3.3.0 build 31.  I see this tool is used in soho and 800 series router but not in cisco 3500. Yet, Im puzzled it might use in cisco 3500 series switches too and suggest if it is used ?
sh version
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAB0547Y1DL, with hardware revision 0x00
Last reset from power-on
sh flash:
Directory of flash:/
  2  -rwx     1749748   Apr 30 2001 10:54:49  c3500XL-c3h2s-mz-120-5.3.WC.1.bin
  3  -rwx       94375   Apr 30 2001 10:54:49  c3500XL-diag-mz-120-5.3.WC.1
  4  drwx       10176   Feb 28 1993 20:00:55  html
  5  -rwx         272   Dec 31 1969 20:00:20  env_vars
165  -rwx          25   Oct 06 1993 22:00:58  snmpengineid
166  -rwx        7680   May 28 2010 09:39:03  vlan.dat
167  -rwx       12217   Jan 08 2013 11:05:34  config.text
3612672 bytes t
In reference i found this document for the CRWS 3.3.0 build
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20060712-crws#software
Jon Marshall
Why do you think this is supported on that switch ?
It is for the 800 series routers not switches.
If you click on the link you give and look at the affected products there is no mention of any switches.
Jon
srikanth ath
Level 4
Level 4
Can you help me with this?
Jon Marshall
Jon
