Crypto map on vlan interface in 2800
gautamzone
Dear friends,
Just wanted to know if we can apply a crypto map to a vlan on a 2800?
The IOS image is 12.4(24)T1 and the feature set is Adv. IP Services.
Thanks a lot
Gautam
Lucien Avramov
Level 10
Level 10
For crypto map you need a crypto image (with K9) in the image filename.
You can check the feature navigator : www.cisco.com/go/fn
Thats fine. I have the k9 image. But i am not sure if i can apply crypto map to vlans
Technically, yes you can, if you have the featureset in your IOS image (k9).
Ok thanks a lot. Will apply it and check.
