DNS problem on cisco router
nitsg.gupta
Hi All,
i have a small network in which i have a router connected to a switch and all the hosts are connected to the switch in different vlans. router is acting as a L3 device to make communication possible between vlans.
problen is that when i ping ip address of google.com it pings but if I try to ping google.com from router, switch and PC it doesn't ping hence i cant browse the internet from my PC.
all the PCs are getting its ip address and other info from dhcp configured on cisco router.
and i've also configured the router for NAT.
what could be the problem.
plz help....
12 Replies 12
francisco_1
Level 7
Level 7
Couple of thing to check...
Is the router issuing default gateway address to your hosts?
Does the router have a route to the internet?
thanks for quick reply
yes, default route is configured thats y i m able to ping WAN ip address.
problem is only with fqdn or browsing.
Nitin,
You need to configure the IP address of the name server
for example:
ip name-server 192.168.1.100
You also need to enable
ip domain-lookup
This command is enabled by default, but lots of operators disabled it.
Reza
i have already configured above commands but still in trouble.
you mentioned you can ping google ip from hosts but cannot access google web page?
exactly..
try enabling dns server on router and use 194.72.6.51 (This is a DNS server on the net)
dns-server 194.72.6.51
or setup dns manaully on a host and try it..
i m using ISP dns and internet dns which is 4.2.2.2
if you can ping but unable to bring up a web page sounds like dns resolution to me. do you wanna try the dns i gave you!
Can you ping the DNS server (4.2.2.2)?
some one blocked UDP port no 53 for some R&D. now users can browse the internet.
thank you very much for your time and help.
ha!. Good to know problem is solved. :)
