crypto maps
carl_townshend
Hi all, can anyone tell me the meaning of crypto map, i have worked with them but dont know the actual meaning ?
jorg.ramakers
Hi Carl
Crypto maps map a DES algorithm to an access list, and also identify the peer routers for encryption services. Need one crypto map per encrypting interface.
regards
Jorg
crypto maps are not limited to DES.
it's not a one crypto map to one peer ratio...you can only have one crypto map per interface, with different sequence numbers (of the same crypto map) for different peers.
