Crypto PKI Trustpoint
Dear forum members, I have a question to ask you before I move on.
While I was building a switch config, I had a pretty similar config from another switch, with crypto pki self signed certificate generated.
When I changed, the VLANs IPs and some other minor information, i loaded the config to a new switch.
By doing so I found out the hard way that https://managementip of the switch was not working and this was due to a certificate error.  DUH.
Off course it would not work since pretty much I was loading a self signed certificate from another switch.
The resolution is simple.
config t
no crypto pki trustpoint  <name of self signed cert>
then I deleted the existing key
config t
crypto key zeroize rsa
and I had to reload the device and after I reloaded successfully, I did the following
config t
crypto key generate rsa gen
ip http secure-server.
the keys were generated and I was able to fix the issue.
MY QUESTION is, can I get away witht he same process without having to reboot the switch?  If I need to reboot the switch will I lose access to the switch using ssh?
The only reason I am asking is because this switch is in another country and I do not have a console cable plugged in to it.
I would appreciate your help on this matter.
AS
cadet alain
as soon as you enter ip http secure-server you're good to go with https.
for ssh you have to do crypto key generate rsa after clearing old rsa keys with the zeroize command but then you will l lose your ssh connection
but you don't need to reboot.
But you can make your keys exportable for routers: http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_key.html
maybe the same goes for switch?
Regards.
alain.
Thank you for your reply, so in other words, if I disabled ssh and I do transport input telnet and transport out
put telnet.
and then do
config t
no ip http secure-server
crypto key zeroi
and then regenerate the keys and reenable ssh
transport input ssh
and
transport output ssh
once I have generate the new keys.
I should be able to do what I need to do successfully right?
Thank you and I would appreciate your reply on the matter.
AS
I would do this:
-no ip http secure-server
-line vty
  transport input telnet ssh
-crypto key zeroize rsa
-crypto key generate rsa
-ip http secure-server
-line vty
transport input ssh
Regards.
alain.
cadetalain, thank you for your reply, prior to reading your second message this is exactly what I did.  it now works.
I appreciate your collaboration on this matter.
Thank you and have a great day
