CSM and VRF (or: multiple client VLANs)
scameron
Is it possible that the CSM can be VRF-aware?
If not, is it possible that you can have two client VLANs, and how can you differentiate where traffic will flow?
Thanks.
There are no issues in mapping the VRF's to the CSM via regular VLANs.
The only exception is if you are using RHI (route health Injection).If you are using RHI, CSM can not injects routes in VRF routing table. RHI only injects routes in MSFC routing table.
Syed Iftekhar Ahmed
The problem is, I want a second client VLAN. But it does not seem that there is any mechanism to tell the CSM to route between 1 client VLAN to another based on any criteria.
I would like to have 'vlan 1 client, gateway 10.0.0.1' and 'vlan 2 client, gateway 20.0.0.1' where traffic from 20.0.0.0/8 might come in on VLAN 2, and should leave on VLAN 2. Other traffic (10.0.0.0/8) may come in on VLAN 1, but leave on VLAN 1.
for each flow that hits a vserver, the CSM does remember the MAC address where that flow came in first and sends the return traffic back there.So return traffic for established flows is not an issue.
If you need to handle non-established conns like server initiated connections, then you'll have to add some configuration.
vserver Outbond
virtual 0.0.0.0 0.0.0.0 any
vlan 100 <------- Server vlan
serverfarm outserver
inservice
no nat server <----- Very important
real 10.0.0.1
ins
where 10.0.0.1 is the gateway that you want to use to go out (of course that also means that you're selecting which vlans to use to send that connection out).
One more caveat here: every flow in the CSM contains also VLAN information, so once you send a flow out of a certain vlan, the return traffic will have to come back from that same vlan, otherwise the connection breaks. In some cases, you'll have to source NAT those connections to specific IPs in order to get them back to the correct vlan.
