CSR 1000v bandwidth very slow
mohammed hashim
hi,
I am using CSR 1000v in my environment and noticed those machines which linked to int gig 2 communicate very slow with machines linked to gig 1,
like if I copy a file, speed is about 300kb
configuration is minimal, only ip addresses are configured with ip routing enabled on the router.
how to troubleshoot it ?
thanks,
Charles Hill
First thing I would do is
show interface g1
show interface g2
and verify how it negotiating speed/duplex.
Verify if there are any errors on the interface.
Speed/duplex mismatch is a common trouble.  Best practice is auto on both sides.
Bare minimum,  interface Gig need to match speed/duplex settings on device on other end of link.
Auto <-> Auto or
hard coded <->  hard coded
Hope this helps,
if so, please rate.
Reuben Farrelly
Level 3
Level 3
What license have you got installed?
I recall reading something about the demo license only allowing around 2Mbit/s of throughput, which is close to what you are seeing.
chris hallman
I've noticed this as well. I have a VM lab running on my laptop host (Linux Mint). I have the guests running in KVM. If I use a Cisco CSR as the router, my web GUI connections to an A10 and Netscaler are SLOOOW. But if I use a VyOS router, they're lightning fast.
