CSS11500 Multisite load balancing
VictorAKur
Is there a way to configure load balancing solution with failover between two sites, using one CSS11501?
didyap
Level 6
Level 6
There's a configuration for the CSSs called global server load balancing, which basically will load balance traffic between CSSs on different locations. Here's a doc that explains how it works:
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_installation_and_configuration_guides_list.html
