CSS11503 question
kope
Level 3
Level 3
Does the CSS11503 ethernet ports support 1 Gig bps? thanks,
Jon Marshall
Not entirely clear what you mean. The 11503 does support gigabit ethernet as well as 10/100 fast ethernet but the gigabit ethernet ports use SFP GBICS whereas the 10/100 support RJ-45.
See attached data sheet, there is a summary table for all 3 models about half way down.
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5719/ps792/product_data_sheet0900aecd800f851e.html
Jon
as shown in the diagram, there is a 16 - port ethernet RJ45 module on the CS11503; looks like they are only 10/100 ports. They do not support 1 Gig ehternet.
You have clarify only the SPF GBICS are Gig ports.
Thanks for your help.
