CUBE & OCS Interrop
Gordon Ross
Level 11
Level 11
I'm having a problem with CUBE (152-1.T) & Microsoft OCS:
For national calls, the SIP call sets up fine. For international calls, as soon as the user has finished dialling, OCS gives an N/U.
Looking at the SIP messages, the main difference is that for National calls, we get a SIP INVITE, and then send a SIP TRYING, followed by a SIP RINGING.
But for International calls, we get a SIP INVITE, send a SIP TRYING, then fairly quickly afterwards, we send a SIP 183 Session Progress. After that, everything goes quiet. We get nothing from OCS, and we send OCS nothing.
I'm guessing that OCS is chocking on the 183 Session Progress.
Thoughts or suggestions ?
GTG
Please rate all helpful posts.
acampbell
Gordon,
From the interoperability portal link
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/8464511.pdf
Early-media negotiation may not be supported due to the new provisional response mechanism implemented on Microsoft
OCS 2007 R2. Microsoft OCS 2007 R2 sends three provisional responses to a single INVITE (183 w/SDP, 180, 183)
which causes incompatibility agaianst Cisco UBE which expects ringback media to flow from the Miscrosoft OCS due to
the 183 with SDP response message (early media indication), but the Microsoft OCS does not send ringback media and
the calling user never hears ringback. The workaround is to use the command “
voice-class sip block 183 sdp present”
and apply it to the appropriate dial-peer, not globally, in Cisco UBE to block all 183 messages from msft OCS toward
Cisco UCM allowing only 180 message to be sent to Cisco UCM and receiving local generated ringback on the calling
side.
Not sure if this is relevant
Alex
Regards, Alex. Please rate useful posts.
