custom stackwise-480 cables lengths
ajamua
Level 2
Level 2
I am trying to design a office with wireless-first network and a very small footprint. The office will have up to 500 employees and there are no plans for a physical ethernet port on each desk. The only wired devices will be POE for conference phones, access points, router, firewall and vm-ware infrastructure. There will be only two floors with a high density of access-points on each floor. I would like to use to cat9300 and use stackwise-480, but I am wondering if I can make custom cables to extend my stack between my two floors? I see the longest length listed is 3m but could it be extended longer and if so what is the maximum length I can extended the members within the stack?
luis_cordova
Hi @ajamua
My recommendation is to use standard stackwise cables and increase the length of ethernet cables.
This is to avoid possible failures in your devices.
Joseph W. Doherty
I doubt your custom cables would support the additional distance, and if they did, "sort of", they wouldn't be supported by Cisco.
Have you considered using a virtual stack?
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-3850-series-switches/q-and-a-c67-738577.pdf
Hello
Pity you couldn't go for Cat 3850,9400 or 9500 instead as they support stack-wise virtual so you can stack over fibre for quite a long distance.
Kind Regards
Paul
