Customer needs a 12 or 16 port Cisco switch
Kevin Melton
Level 2
Level 2
Forum
I have a customer whom is requesting to see quotes for either a 12 port or 16 port Cisco switch.  The switch must do 10/100/1000 on each of its ports, and have the ability to do SFP uplinks.
I have searched the Cisco Web, and have also contacted Partner support.  Both efforts have proven futile.
I am able to find 10/100 switches in the SMB line and in the Enterprise line.
Does anyone know of a managed switch that will do SFP uplink, POE, 10/100/1000 that comes in port density 12 or 16?
Thanks in advance!
Kevin
Leo Laohoo
Oops!  Missed the 1Gb requirement.
The answer is:  There's no 12- or 16port 1Gb switch with SFP.  The cheapest is either the 2960S-24TS or 3560G-24TS.
Not sure about Linksys product.
6 Replies 6
Leo Laohoo
How many?
Look at this:  WS-C3560-12PC
There is no 16-port switch unless you are planning to purchase a network module for a router.
Reza Sharifi
There are 24 port and 48 port 10/100/1000 POE 3560G with SFP uplinks.
Cisco Catalyst 3560G-24PS: 24 Ethernet 10/100/1000 ports with PoE and 4 SFP-based Gigabit Ethernet ports; 1RU
• Cisco Catalyst 3560G-48PS: 48 Ethernet 10/100/1000 ports with PoE and 4 SFP-based Gigabit Ethernet ports; 1RU
Leo Laohoo
Thanks for verifying what I thought must be the correct answer after relentless searching!
Thanks for the ratings Kevin.
As an alternative to a general cisco.com search, have a look at the Cisco Product Quick Reference Guide. It's updated pretty regularly and is a good one-place overview of the various products.
http://www.cisco.com/en/US/customer/prod/qrg/index.html
Hope this helps.
