%DAEMON-3-SYSTEM_MSG: ERROR, mts_send failed,
This error came in at the same approximate time other issues came up, and I can't seem to figure out what it means.  The error message decoder doesn't come up with anything.  It's appearing on a cisco Nexus 1000V Chassis
nkarpysh
Can you please collect and provide the following information additionally:
# show clock
# show version
# show system internal mts event msgs
# show system internal mts event errors
# show system internal mts buffer detail
Nik
HTH,
Niko
Here is the output of those commands.
John
This message should be triggered by some protocol failing I guess. Then MTS is trying to messages all the rest processes of it and fails for some reason.
There is one DDTS which was not fixed:
CSCtr25346 %DAEMON-3-SYSTEM_MSG: ERROR, mts_send failed, ERROR=-1, ERRNO=9 - syslog
DE suspected SNMP process failure there. If you want to dig that deeper you will need to open the TAC case to get  in touch with those BU engineers and continue troubleshooting.
Nik
HTH,
Niko
