DAI basic questions
gautamzone
Level 6
Level 6
Hi friends,
Just a basic clarification on the working of DAI. If i configure dhcp snooping and dynamic arp inspection on a switch for vlan x,y but some of my access ports are in vlan z.
Does it mean that hosts in vlan z will be denied access as they will not be found in DHCP snooping binding table?
In such a case, is it necessary to configure all access ports in vlan z as ip arp inspection trust access ports?
Thanks a lot
Gautam
smalkeric
Level 11
Level 11
DAI is supported on access ports, trunk ports, EtherChannel ports, and private VLAN ports.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2ZY/configuration/guide/dynarp.html#wp1064197
