06-01-2016 07:13 AM - edited 03-08-2019 06:01 AM
Hello ,
I have my Nexus 5000 with Fex 2232, could I connect my Dark Fiber to my FEX or should I have it connected directly to my 5000?
Thanks.!
06-01-2016 07:59 AM
Yes, you can use the available fiber to connect them together. It does not have to be a direct connect.
06-01-2016 08:16 AM
Hi -
Spec sheet for the N2K states that you can use SFP-10G-LR modules. This gives you an effective range up to 10Km. I can't find any documentation stating that you can use ZR or ER modules, so don't expect to go beyond 10Km.
PSC
