dc switch
rahman001
Level 5
Level 5
Hi everyone,
please i need a part number of a cisco switch with the following spec:
A: - Cisco Switch With 48 port–
GENERAL SPECIFICATION
  • i. Enterprise-access Layer 3 switching, including Open Shortest Path First (OSPF) for routed access
  • ii. Each Switch should have 2 x -48 DC Power Supplier
  • iii. Supporting VLAN and IP 6
  • iv. At least Two x 1-Gb Ethernet uplinks
  • v. Ensure data confidentiality with MACSec layer-2 encryption
  • vi. Support non-stop communications with redundant power supplies and cooling fans
  • vii. Minimize downtime with hot-swappable power supplies, cooling fans and network modules
  • •viii. 1RU size
  • ix. Preferred 35XX series
Though 35xx series is end of life but give me the latest switch that has the above specification.
br
sam
dominic.caron
Level 11
Level 11
dominic.caron
Level 11
Level 11
3560X
Hi dominic,
i have check as well but i see that WS-C3560E-48TD-SD is equally a DC powered switch but will be eol by january 13th.
so what is the exact part number of the 3560X DC switch?
br
sam
WS-C3560X-48T-E
That will give you a 48 ports switch with no POE and an AC power supply. You need to order 2 DC power supply and change it.
2 X C3KX-PWR-440W
For the uplinks, you would need
1 X C3KX-SM-10G
The uplink module will give you macsec for the uplink will operate at 1 Gbps of 10 Gbps with SFP or SFP+ optic.
Plus it is not EOL either
