DCNM LAN JAVA Client Not working
gopi_sivam
Community Member
Hi ,
Recently i installed the DCNM server , we are using nexus 7k in dc environment . I  purchased the DCNM server license and assigned it to  switches thourgh web dcnm client . Login in Java DCNM LAN is  not working , It says check your username/password . Only with SAN its working Fine , Authetication to the dcnm is configured to check the TACACS server  . Can you help on this.
Thanks , Vedagiri Gopinath
Hello
have you verified tacacs is working as it should?
test aaa server tacacs+ x.x.x.x (user) (password)
test aaa group (group) (user) (password)
res
paul
Kind Regards
Paul
