DCNM LAN JAVA Client Not working
gopi_sivam
Community Member
Hi ,
Recently i installed the DCNM server , we are using nexus 7k in dc environment . I  purchased the DCNM server license and assigned it to  switches thourgh web dcnm client . Login in Java DCNM LAN is  not working , It says check your username/password . Only with SAN its working Fine , Authetication to the dcnm is configured to check the TACACS server  . Can you help on this.
Thanks , Vedagiri Gopinath
Leo Laohoo
Duplicate posts.  😛
Go here:  http://supportforums.cisco.com/discussion/12164196/dcnm-lan-java-client-not-working
