DEAD 2940?
edemusmaximus
Not really dead, but just made the mistake of erasing the flash and NVRAM. Anyways, I am fairly new to networking, and I am trying to load the IOS to the flash. How do I do that? TFTP server? What is the actual, step by step command?
sachinraja
Level 9
Level 9
Is the switch on rommmon mode now? If so, you can use the xmodem commandsets to upload the IOS through the hyperterminal. You have to be on the console of the switch for this. you can then use the command :
xmodem -c imagename 115200
where 115200 is the speed at which the upload will happen..
Refer to this link for more info:
http://cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Hope this helps.. all the best... rate replies if found useful..
Raj
Thanks Raj, I think that will work.
Test it and let us know in case of any issues.. if it works, mark the case as solved, which can help others.. rate replies if useful.
Raj
