Deadline in two days, just realized there is a problem.
Denis Mlynarcik
I was setting up VTY on the router, but it's my first time doing something like this so I accidentally put Vlan50 and Vlan90 before I realized how to do it. I only want Vlan99 to be there. Is there a way to remove Vlan50 and Vlan90? And for some reason, I can't turn Vlan99 on. Thank you in advance for your reply
if you want to remove the subinterfaces and the Vlans, configure the below:
Device#conf t
Device(config)#no interface GigabitEthernet0/2.50
Device(config)#no interface GigabitEthernet0/2.90
Device(config)#no vlan 50
Device(config)#no vlan 90
Is there any up/up port configured for Vlan 99 ? Post the full running configuration of the device...
Device#conf t
