Debug Help
dan_track
Level 7
Level 7
I'm having trouble with some connections to a server. I'd like to see where packets are going to in the switch. I have a 3500xl switch. I would appreciate if someone could show me how to capture packets and read there tcp headers. I'm quite sure you'll need to use debug, but am not having much success with it.
Any help would be much apprecaited.
Dan
jackyoung
Level 11
Level 11
When you enable the debug, the result will show on the screen. So you have to turn on the capture of the terminal software before start the debug. However, if you debug all traffic, it will create high loading on the device, beware not to debug everything. Moreover, the debug will show you the event and not the traffic content.
If you really want to capture the traffic content, you better span the port/vlan to a port and connect a Sniffer type machine to capture the traffic.
Hope this helps.
