Debug output does not display on my Router
Imran Ahmad
Level 2
Level 2
on my Firewalls and Routers, when turn on Debugging .  I do never see any outputs.  can anyone tell me what is the issue ? how can I resolve please
Mark Malone
HI try set terminal monitor if your over an ssh connection or logging console if directly consoled in by default it does not log to monitor
https://www.safaribooksonline.com/library/view/cisco-ios-in/0596008694/re826.html
Thank you all
Np and you are welcome.
One last thing would be to rate useful posts if you found these posts useful.
Madhu.
Agree with Mark. Also if you are not enabling the below (which personally I believe not a good practice if your debug is very agressive as you may have hard time to stop it) check "sh log" to see the debug output.
Madhu.
