10-16-2011 12:47 AM - edited 03-07-2019 02:49 AM
Can someone let me know the debugs which can be used to see cdp and lldp power negotiation of cisco poe switches with phones etc.I have some phones which take abt 15w with one switch,and same phone takes abt 7w with another switch.Just want to see the debugs why the power negotiation is not happening...thanks.
Solved! Go to Solution.
10-16-2011 12:52 AM
I can't answer that, but how about this: Troubleshooting Power over Ethernet (PoE)
There's a section called Debug and PoE.
10-16-2011 12:52 AM
10-16-2011 12:57 AM
Hey,thanks for prompt reply...I was looking for debug ilpower.
10-16-2011 12:59 AM
So I didn't answer your query?
10-16-2011 01:06 AM
Well,i got only from the document you referred
10-16-2011 01:20 AM
Ok. There are some stuff there about "debug ilpower".
As you can see, this document is fairly outdated. Maybe you can create a document bug and include TDR in it?
10-16-2011 01:32 AM
Well,documentation team will take care of only those documentation bugs which are in the config guide..Let me send a mail to Documentation team of 3k series to make one similar document for 3750 X(which has additional poe capabilites),and include tdr in it..Chances of getting to conclusion are pretty less,but lets try.
Or let me ask them if i can write one myself,if they can publish that after review.
10-16-2011 01:35 AM
COOL!
10-16-2011 01:36 AM
What models are these two switches?
10-16-2011 01:41 AM
These are 3750 X ..This is just the test setup...Many other things can go wrong even without a wrong in switch
