declaration of conformity
drascii77
Hi all,
After an inspection of the italian authority i need  the "declaration of conformity" of cisco 2621xm and cisco 2811.  Where can i find it ?
Consider that i have gave the following documents, but for the italian authority are not sufficient.
Can someone help me ?
Leo Laohoo
You will need to contact your Cisco AM/SE and they will dig up the relevant documentation for you.
On cisco.com i cant find anything ?
You could but the database is very big.  You'll get better and faster response if you engage your Cisco AM.  If you create a TAC Case, the agent may recommend you contact your Cisco AM as well.
