default gateway for switch management
carl_townshend
Hi all, on my 3550 switch, I have several vlans, for the default gateway for management I have set this as the ip address of one of the vlan interfaces, is this correct ?
bvsnarayana03
Level 10
Level 10
Yes this is correct. On L2 switches you can have only 1 active management VLAn interface, while on L3 there can be many.
hi there, so could i set the default gateway as any of the vlan interface ip addresses ?
are you using your 3550 as a layer 2 or layer 3 switch? ie is the "ip routing" command enabled? if so, it's layer three, and your default route (not default gateway) takes priority.
Now, if yo'ure talking about setting the default gateway on each of the hosts in each vlan as the respective vlan interface, then yes, that's how you would normally enable inter-vlan routing in this situation.
