Default Gateway on different subnet to DHCP
geoffknight
Hi, help needed please for a charity in Kenya. I have inherited a router for the main internet connection on site. The config has been (mis)managed by the ISP up to now. I am no router expert so I desperately need some help. It is a Cisco 887. The behaviour seems very strange with the default gateway witnessed at each  of the clients seems to change from 192.168.0.1 to 192.168.1.1. The changes may  be caused by intermittent power to the router (trying to fix this!).  This causes problems for clients. DHCP pool appears to be 192.168.0.1 and therefore regularly on a different subnet to the router. I can't see how this ever worked, but with increasing need for wifi we are having big problems. A redacted config is below.
Could you give some hints on how to fix or why it would be configured this way please?
Many thanks... (please don't assume much networking or ios command knowledge)
"ip source-route
ip dhcp pool OURNAME
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.1.1
dns-server x.x.x.x y.y.y.y //removed
lease 0 2
ip dhcp pool excluded-address 192.168.1.1
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip name-server xx.xx.xx.xx
ip name-server yy.yy.yy.yy.
no ipv6 cef
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description INTERNET
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet4.883
description ISPNAME //this is the name of our ISP
encapsulation dot1Q 883
ip address xxx.xxx.xxx.xxx 255.255.255.252  //this is the external IP address
ip nat outside
no cdp enable
interface Vlan1
description LAN
ip address 192.168.0.1 255.255.255.0 secondary
ip address 192.168.0.127 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Dialer0
no ip address
ip nat outside
no cdp enable
interface Dialer1
no ip address
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 102 interface FastEthernet4.883 overload
//load of nat rules which we probably don't need and don't work
ip route 0.0.0.0 0.0.0.0 yyy.yyy.yyy.yyy //this is a second external IP address
7 Replies 7
Harold Ritter
Hi Geoff,
You should change the following two commands as follow:
to:
default-router 192.168.0.1
ip dhcp pool excluded-address 192.168.0.1
thanks will try this.
Rich Uline
Geoffknight,
Taking a cursory glance at your config, I find the following issues:
  • You should never allow the source of the traffic tell the router how to route.
  • Your DHCP pool is using a default-router outside of its subnet.
  • On the VLAN 1 SVI, you have an unnecessary IP address assigned.
Additionally, because you have a static IP on Fa4.883 and you are a stub, you should specify both the next-hop IP and the exit interface if your device allows it. You are missing a lot of basic security settings as well, but I think the scope of which is too large to go into here.
no ip source-route
ip dhcp pool
 no default-router 192.168.1.1
no ip route 0.0.0.0 0.0.0.0 yyy.yyy.yyy.yyy
ip route 0.0.0.0 0.0.0.0 Fa4.883 yyy.yyy.yyy.yyy name DEFAULT_ROUTE_ISPNAME
int Vlan1
 no ip address 192.168.0.1 255.255.255.0 secondary
Try making these changes and let us know how it worked out for you.
Thank you - very helpful.
What does this command do?
 and I assume I don't need this on VLAN1?:
Thanks again.
Hello
Just like to add - Not sure why you have secondary addressing on the svi vlan1 interface?
Also I don't see any access-list 102 for the nat translation.
So with the other suggestions i would say also create an access-list if one isn't already applied
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
res
Paul
Kind Regards
Paul
I have the access list actually, I just hadn't posted - apologies.
I don't understand what the secondary addressing would be doing. Removing the 192.168.0.127 address (which isn't correct), seems to have removed that 192.168.0.1 secondary address and the interface has no ip address.
apologies for stupid questions, but if I run:
conf t
int Vlan1
It should commit to config again right? This does not seem to work.
Hi Geoff,
Since you have only one ip address on the interface. you do not need the secondary keyword.
