SNMPv3 failure
tedauction
Level 5
Level 5
Hello, I have been trying to convert existing SNMPV2 to SNMPv3 on multiple switches and routers but it is failing.
This is the config I have been using:
snmp-server view ALL-ACCESS iso included
snmp-server group myGroup v3 priv read ALL-ACCESS
snmp-server user myUser myGroup v3 auth sha ~4q^gL]9H4~X>>Z; priv des [3Z&Waaw!=%U_M{r
I continually receive 'could not create SNMP session' errors. I have tried to use a very simple password and I have tried by removing the encryption component. Nothing succeeds.
I attach the full config of the Cisco router (which includes the exising SNMPv2 config.
Thank you kindly for any help.
Can you show the output of the command show snmp user?
Hello, here is it:
#sh snmp user
User name: myUser
Engine ID: 8000000903001005CA2AB3A0
storage-type: nonvolatile active
Authentication Protocol: SHA
Privacy Protocol: None
Group-name: myGroup
