default gateway v ip route
j44mistry
I have a Cisco 2960 ( WS-C2960-8TC-S)  running 12.2(46)SE  C2960-LANLITEK9-M  image.
I would like to set an ip route 0.0.0.0 0.0.0.0 87.101.156.97  but the current image does not allow.
Will ip default-gateway 87.101.156.97 work or do I need ip routing ?
The ISP has provided a /30 address and we are using an additional /29 for our network devices.
I dont think this image can be upgraded.  I need to forward routes directly out to ISP.
interface FastEthernet0/1
description Internet ISP
switchport access vlan 70
interface FastEthernet0/2
description Production LAN
switchport access vlan 75
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan70
ip address 87.101.156.98 255.255.255.252
no ip route-cache
interface Vlan75
ip address 87.101.156.126 255.255.255.248
no ip route-cache
5 Replies 5
mahmoodmkl
Level 7
Level 7
did u enable ip routing
ip default gateway will not do the job
Yes there is no option on this C2960-LANLITEK9-M image.
mahmoodmkl
Level 7
Level 7
i think this version doesnt support routing
u need to look for other options
Yes ordering router instead as this image cannot be upgraded.
ip route is supported only in router and L3 switches. ip default GW is  for pure  L2 swiches only applicable  for management IP  Only.It will not route vlan traffic
