default interface for ping
Mary
Level 5
Level 5
from router 1, i am ping switch 1. not successful, but if i use source lo1, i am able to ping,
when we use ping command, which default source interface from router 1 is used to ping other host?
8 Replies 8
Jon Marshall
The interface ping will use as the source interface is the one the routing table says is the interface used to reach the destination IP.
Jon
then why adding souce lo1 succeed and without source command failed?
Don't know without seeing configurations etc.
Jon
I would guess the switch does not have a route for the interface IP but it does for the loopback IP.
Jon
Destination device, or device(s) in between (?), might also have ACL that block pings from some IPs.
Hello
Because most probably the destination devcie you pinged had a valid route back your lo0.
If you do a trace route back from your destination to the each of the connected interfaces on the source device you may find out the reason reason why?
Kind Regards
Paul
Carlos Villagran
his behaviour usually occurs when the destination device does not have a route back to the subnet where it was ping'd from.
So lets say you ping 10.1.1.1 from your source interface VLAN whic is 10.1.2.1.
1. The 10.1.1.1 host does not have a Default Gateway configured (the destination is in another subnet).
2. The 10.1.1.1 is not an end host but a router or a switch and it does not have a route to 10.1.2.0/x subnet.
Regards!
mdrakes
Community Member
In Cisco routing, the default source interface is the IP of the connected interface used to exit the source device. Routing must work both ways; R1 must be able to reach SW1, and SW1 must be able to reach R1. Your ping from R1 to SW1 works when using lo0 because SW1 only knows how to reach the IP of R1's lo0, and not the IP of the connected interface used to exit R1.
