Showing results forĀ
Search instead forĀ
Did you mean:Ā
Default Native VLAN
Muhammad Haseeb
Community Member
The Default Native VLAN is 1 in Cisco Switches. How can we change it to other  than 1 .? Any Help........
smitesh kharecha
Level 10
Level 10
You can change it by command
switchport trunk vlan X native ( where X is vlan which you want it to vlan )
HTH,
Smitesh
