default route and routing protcols
sarahr202
Level 5
Level 5
Hi everybody!
i have few questions:
In the following default route,
ip route 0.0.0.0 0.0.0.0 192.192.192.1
192.192.192.1 is next hop ip address.
Consider the following routing table:
R 199.199.199.0 [120/2] via s0
c 192.192.192.0 is directly connected.
Can i configure a default route as.
Ip route 0.0.0.0 0.0.0.0 199.199.199.2
Here 199.199.199.2 is not the next hop but a an entry from routing table.
I think router will perform recursive look up to send packets using 199.199.199.2
Am i correct?
2) Consider the default route:
ip route 0.0.0.0 0.0.0.0 199.199.199.1
Now in case of rip, rip will automatically advertises the default route .
But in case of eigrp and ospf, we need to redistribute this route using "redistribute static" command. Am i correct?
3) Consider the following routing table
R 199.199.199.0 via s0
C 192.192.192.0 directly connected s0
If i configure default route as:
ip route 0.0.0.0 0.0.0.0 s0
it will appear in the routing table as
C 0.0.0.0 directly connected s1.
Now if we wish to advertise this route using eigrp and ospf, do we need to use the command " redistribute connected" ?
Thanks a lot and have a nice day!
17 Replies 17
Steven,
You mean requirements as for memory and flash? There isn't as everything is virtual. You set your own limitations in term of memory and flash according to your workstation capabilities.
For instance, you can run more virtual router instances if you download an image that requires only 96MB DRAM vs an image that requires 256MB DRAM.
HTH,
_
Edison.
Sorry Sarah :(
Edison Ortiz
Hi Sarah,
I was playing a little more about this subject and found another way to bring a default into RIP.
1) Create an IP route pointing to an interface
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
2) Have network 0.0.0.0 under RIP
R1#sh run | be router rip
router rip
version 2
network 192.168.12.0
network 0.0.0.0
no auto-summary
Here is the remote router's view:
R2#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "rip", distance 120, metric 1, candidate default path
Redistributing via rip
Last update from 192.168.12.1 on FastEthernet0/0, 00:00:07 ago
Routing Descriptor Blocks:
* 192.168.12.1, from 192.168.12.1, 00:00:07 ago, via FastEthernet0/0
Route metric is 1, traffic share count is 1
And the router generating the default is marking it as a 'candidate default path' so in essence is doing a 'ip default network'.
R1#sh ip route 0.0.0.0
Known via "static", distance 1, metric 0 (connected), candidate default path
Advertised by rip
* directly connected, via FastEthernet0/1
Route metric is 0, traffic share count is 1
More information on the ip route command can be found in the 'Usage Guidelines'.
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_ip.html#wp1012824
HTH,
__
Edison.
