Default setting for Cisco 2950 Switch
Nikos5555
Hello, I was wondering what the default administrative mode is on the switch interface ports?
Do they form trunks automatically when connected to other switches?
9 Replies 9
JORGE RODRIGUEZ
Level 10
Level 10
default on switch with no configuration for all ports is vlan 1 including any gigabit uplink ports if any, no other configuration is set for any type of trunking unless it is manualy configured for trunking or dynamic trunking.
-Jorge
Jorge Rodriguez
Right O, thanks
jcoke
Level 3
Level 3
The default mode on the 2950 is dynamic desirable so it will actively seek a trunk on a connected switch.
Is that correct? because that contradicts the other post.
In my experience for a switch that comes with no configuration I have always manualy make a switchport wether is a normal 10/100/1000 access port or gigabit port to participate in trunking either dynamic or non-dynamic, whether this has changed that ports defaults to dynamic on all ports I am not aware of it.
The simplest way to find out would be to have your switch connect to another switch to see if it auto negotiates DTP.
-Jorge
Jorge Rodriguez
I know it conflicts, but I asked the switch and it told me so
#sh ver
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA10a, RELEASE SOFTWARE (fc2)
cisco WS-C2950-12 (RC32300) processor (revision B0) with 19918K bytes of memory.
Running Standard Image
12 FastEthernet/IEEE 802.3 interface(s)
#sh run int f0/1
Building configuration...
Current configuration : 33 bytes
interface FastEthernet0/1
end
#sh int f0/1 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
#sh interfaces f0/1 trunk
Port Mode Encapsulation Status Native vlan
Fa0/1 desirable 802.1q not-trunking 1
He is correct , default is dynamic desirable so if you plug into a cisco switch on the other end and the port is set as desirable or auto it will form a trunk .
I guess jcoke is the winner then, new info learned ! and deserves a good rating.
Jorge Rodriguez
Thanks for your efforts guys, really appreciate it!
