Default Vlan
pbvijay1223
Community Member
Hi All,
why are we disabling Default VLAN? What is the Advandage and Disadvandge behind that?
Thank you
Vijay K
aijaz802
Level 5
Level 5
Hi Vijay,
VLAN1 carries certain traffic (CDP, PAgP, DTP, VTP, etc) used by the switches. It's also the default VLAN for all the switch ports. So the idea is not use it for anything else. No compelling reason other than lets keep traffic that has to traverse
vlan 1 from mixing with user traffic and also improves security to a certain extent.
Pls. go thru this link for detailed info..
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008013159f.shtml
Pls. rate if it helps..
*aijaz*
Thank you Soo Aijaz. It was really helpful information
robert.horrigan
Level 5
Level 5
Years ago before there was any great switch hardening (stp, trunking) we liked to change the default management and user vlans to another number for for security reasons. Now it's not such a huge deal as there are other mechanisms to prevent other devices from impacting the network, however, this practice is still carried today....just because we like to change the defaults i guess.
Thank you Robert. It was a really helpful information
