Define Trunk
lynneshri
Community Member
Dear All,
We recently bought 5 Cisco C9200 switches, and we configured them as a stack. My question is, is there a different command for trunking when the switch is configured in stack mode? I want to configure the uplink port (Active Switch) as a trunk on the active switch and then I can configure different ports from switch 1,2,3,4 and 5 for different VLANs and then I can connect my devices to these ports.
Please let me know if I am on the right path.
Thanks in advance.
Lynnshri.
2 Accepted Solutions
Hi @lynneshri
 No, the trunk configuration is exactly the same for stack and non stack switch
 Just get in the interface mode and use the commamd switchport  mode trunk
M02@rt37
Hello @lynneshri,
Right! The configuration for trunking remains the same as when configuring a standalone switch. You can configure the uplink port on the active switch as a trunk and then assign different ports on each switch in the stack to different VLANs.
Best regards
7 Replies 7
Hi @lynneshri
M02@rt37
Hello @lynneshri,
Best regards
Thank you very much.
You're welcome @lynneshri
Best regards
There no different at all between standalone and stack SW trunk config.
Select right port and config it as trunk.
Joseph W. Doherty
In a stack, the only difference you should see is interface numbering prefixed with stack member number.
lynneshri
Community Member
Thanks a lot for your help.
