Deleting IOS from 3 Stack switches
mahesh18
Level 6
Level 6
                   Hi all,
Is there any command that i can use to delete the IOS from 3 stack switches at same time?
I can do it manually one by one but curious to know if any command exists?
MAhesh
2 Accepted Solutions
Hi Mahesh,
As Leo noted, the command you found is when you are loading a new IOS using .tar file and in the process deleting all the old images from all the switches. This works just fine.  My understanding from your original post was that you are looking for just a delete command and not necessarily for loading new images and deleting the old ones.
Reza
archive download-sw /overwrite /destination-system 1  /destination-system 2 /destination-system 3 /destination-system 4 tftp:/1.2.3.4/filename
Where 1 2 3 and 4 are name of switches in stack
Yes, this is the correct command-switch.
10 Replies 10
Reza Sharifi
Hi Mahesh,
Looking at the command reference guide, there is no option for deleting all flash files at the same time:
Switch#delete /force ?
  /recursive  Recursive delete
  flash1:     File to be deleted
  flash:      File to be deleted
  nvram:      File to be deleted
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/command/reference/cli1.html#wp1861193
Hi Reza,
after doing some research i found this command
archive download-sw /overwrite tftp://1.2.3.4/filename
Need to confirm here if it can do the job?
MAhesh
Hi Mahesh,
Reza
Leo Laohoo
To delete a file/subdirectory from three 3750 stacked switches, the commands are:
delete /f /r flash1:
delete /f /r flash2:
delete /f /r flash3:
This command only means to copy the TAR file from the TFTP server into the MASTER stack member and delete the old directory.  If your master stack member has multiple IOS subdirectory, it will only delete the LATEST one.
So if you have multiple stack members in a stack, you need to add the command switch "/destination N".
Hi Leolaohoo,
Thanks for reply.
Do you mean this command to use ?
Switch#archive download-sw /overwrite /destination-system  1,2,3,4 ?
% Unrecognized command
Switch#archive download-sw /overwrite /destination-system  ?
  1  download software to system 1
  2  download software to system 2
  3  download software to system 3
  4  download software to system 4
Switch#archive download-sw /overwrite /destination-system  1 2 3 4 ?
It takes only 1 switch option at time.
MAhesh
Hi leolaohoo,
Found this command will this be ok
Switch/Stack Mac Address : 58bf.ea3f.ee00
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 58bf.ea3f.ee00     8      1       Ready
2       Member 58bf.ea66.2d80     6      1       Ready
3       Member 58bf.eae5.c580     4      1       Ready
4       Member 58bf.eaf1.7680     2      1       Ready
Need to confirm if this command is good to go?
MAhesh
Hi leolaohoo,
Many thanks i will try this command next time.
Mahesh
I used archive download-SW /overwrite tftp://1.2.3.4/filename but the old IOS is still showing into stack switch 2960X flash, when i try to delete manually, it is not allowing me,
Please advise
