Deleting smm.log in /var/tmp for nexus 5596 upgrade
leolink1
I am trying to upgrade a cisco nexus 5596 switch and the system has indicated insufficient space in the directory /var/tmp.    a deeper look into the /var/temp has shown that smm.log file is taking most of the available space. I therefore need help from the community to:
1. understand what smm.log is/does
2. how do i delete the smm.log file from /var/tmp from this 5596 platform?
7 Replies 7
marce1000
 About 2) you may try : filesys delete /var/tmp/smm.log
M.
Many thanks for the reply.
Is this a hidden command on the platform? I tried to confirm the command but it says invalid.
Filesys command is not recognized or invalid on the nexus 5596.
SWITCH-X3# filesys?
% Invalid command at '^' marker.
 - Did you also try   switch # del/var/tmp/smm.log
 M.
the filesys delete /var/tmp/smm.log is a hidden command. I will try that.
thanks.
 - Please inform the us of the result of your actions too (tx).
 M.
I tried to issue the command , it says invalid, is this a hidden command on the platform?
SWITCH-X3# filesys ?
SWITCH-X3# fi?
find Find a file below the current directory
I use the filesys delete /var/tmp/smm.log  (its a hidden command )to clear the smm.log file from the nexus 5596 switches and I was able to successfully execute the install all command.
it worked.
Thank you all
