Dell Switches
abarb002
Against my recommendation, my employer decided to purchase 3 new switches (1-s3048/2-s4048) that were Dell to go along with the new server's we purchased from Dell. I am able to gain connectivity to the network, ping back and forth, and I've even accessed a port (on the Dell) via my laptop and am able to connect to other switches (Cisco) remotely via ssh. However, when I attempt to connect the Dell switches via ssh nothing happens. I get the following log message below on the Dell switch:
*Login Failure for user admin on line vty 0. *
Has anyone experienced this?  I can't post my configs because I work in a secure closed network. I think I tried everything I can think of the last three days.
Reza Sharifi
You may want to try and post this in a Dell forum if there is one.
Not a bad idea. Will do that now.
can you post the output of:
show ip ssh
Since you cannot post the config, check if user admin has the right privilege level (15). What authentication method is configured under the VTY lines, local or TACACS ?
Not sure what you have tried, but you could zeroize and reenter the RSA key:
console>enable
console#config
conole(config)#crypto key zeroize rsa
console(config)#crypto key generate rsa
console(config)#crypto key generate dsa
console(config)#ip ssh server
I'm using radius, but I'll try this and let you know how things go.
