Designing MSTP between CISCO and HP Switches
nawazi
I need to redesign MSTP bcz i am seeing topology changes between Access switch and core switch within 10 seconds
Every switch including multilayer switch has its own region and CIST is formed between  regions .And when CIST root bridge changes  between two regions it is not propagated to third region
(so we don’t see root bridge change on  other switches at the same time).
How should i design MSTP topology
Each floor has its own data vlan but same voice vlan.
Should i configure  1  mstp region and 1 mstp instance with all vlans mapped ?
Should i configure  instance 1 with mapped vlan 3,10,20,60 and 200  and instance 2 with vlan 11 and instance 3 with vlan 12 ?
nawazi
topology changes are logged on HP switches . It is intermittent
MST Instance ID : 0
Root Changes Counter : 8683
Current Root Bridge ID : 24576:5006ab-8b6980
Root Bridge ID Date Time
24576:5006ab-8b6980 07/03/18 11:11:33
61440:70106f-34204a 07/03/18 11:11:32
24576:5006ab-8b6980 07/01/18 03:04:17
61440:70106f-34204a 07/01/18 03:04:14
24576:5006ab-8b6980 06/26/18 15:52:00
61440:70106f-34204a 06/26/18 15:51:59
24576:5006ab-8b6980 06/26/18 13:00:01
61440:70106f-34204a 06/26/18 13:00:01
24576:5006ab-8b6980 06/22/18 15:50:33
61440:70106f-34204a 06/22/18 15:50:32
