05-05-2019 09:35 PM
my name is Edwin
I'm a student and I'm working on the this assignment and I'm having trouble with it
I trying to ping PC5 from PC0, but it keep saying Destination Host Unreachable. Can someone take a look and give some solution?
Thank you
05-05-2019 10:00 PM
Hi @EdwinGoodridge1872 ,
The routers must have a route marked for all the networks of your topology.
You can achieve this with the RIPv2 protocol:
Router0
Router(config)#router rip
Router(config-router)#version 2
Router(config-router)#no auto-summary
Router(config-router)#network 192.168.43.0
Router(config-router)#network 192.168.43.16
Router(config-router)#network 192.168.43.32
Router1
Router(config-router)#network 192.168.43.4
Router(config-router)#network 192.168.43.48
Router(config-router)#network 192.168.43.64
Router2
Router(config-router)#router rip
Router(config-router)#network 192.168.43.8
Router(config-router)#network 192.168.43.80
Router(config-router)#network 192.168.43.96
Router3
After those configurations, the ping will be successful.
Remember to mark the correct answers as solved, since that helps other users with similar doubts.
05-05-2019 10:23 PM
Another way to achieve connectivity can be through static routes:
Router0
ip route 192.168.43.48 255.255.255.240 FastEthernet4/0
ip route 192.168.43.64 255.255.255.240 FastEthernet4/0
ip route 192.168.43.80 255.255.255.240 FastEthernet4/0
ip route 192.168.43.96 255.255.255.240 FastEthernet4/0
Router1
ip route 192.168.43.16 255.255.255.240 FastEthernet4/0
ip route 192.168.43.32 255.255.255.240 FastEthernet4/0
Router2
Router3
ip route 192.168.43.48 255.255.255.240 FastEthernet5/0
ip route 192.168.43.64 255.255.255.240 FastEthernet5/0
ip route 192.168.43.80 255.255.255.240 FastEthernet6/0
ip route 192.168.43.96 255.255.255.240 FastEthernet6/0
