Destination Host Unreachable
netacaduser
I am trying to ping the server from PC3 and PC4 only (green highlighted) however, I keep getting destination host unreachable. I am not sure what's incorrect.
Please advise - I have attached the packet tracer file within the zip folder as it does not allow me to attach the .pkt file.
Thanks in advance for all help.
here are the configs (important parts marked in bold). I rearranged the interfaces on the switch a bit.
Switch#sh run
Building configuration...
Current configuration : 2787 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 100
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 200
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 300
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 70
interface FastEthernet0/8
switchport access vlan 999
switchport trunk allowed vlan 2-99,101-199,201-299,301-1001,1005
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
description Trunk to Router
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Router14#sh run
Current configuration : 1082 bytes
version 15.4
hostname Router14
ip cef
no ipv6 cef
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.100
encapsulation dot1Q 100
ip address 192.168.1.254 255.255.255.0
interface GigabitEthernet0/0/0.200
encapsulation dot1Q 200
ip address 192.168.2.254 255.255.255.0
interface GigabitEthernet0/0/0.300
encapsulation dot1Q 300
ip address 192.168.3.254 255.255.255.0
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/2/0
ip address 80.50.10.1 255.255.255.252
interface Serial0/2/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 80.50.10.2
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Router12#sh run
Current configuration : 1079 bytes
version 15.1
hostname Router12
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524KS6L-
license boot module c1900 technology-package securityk9
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
no ip address
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
interface Serial0/1/0
ip address 80.50.10.2 255.255.255.252
clock rate 2000000
interface Serial0/1/1
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 80.50.10.1
line con 0
line aux 0
line vty 0 4
login
end
6 Replies 6
there are numerous issues with your network:
1. no link between the routers
2. no default route (or routing protocol running) on the routers
3. switchports do not correspond to Vlans created on router
Find attached the revised, working file. I saved it in Packet Tracer version 7.3, if you cannot open it, I'll send the configs as text files...
Hi Georg,
That's really helpful thank you - Are you able to send me the config as a text file so I can see exactly what was changed (or if you could explain)?
Thanks again!
Switch#sh run
version 12.2
hostname Switch
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Router14#sh run
version 15.4
hostname Router14
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router12#sh run
version 15.1
hostname Router12
ip cef
no ipv6 cef
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
no ip address
clock rate 2000000
clock rate 2000000
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Brilliant thanks so much!
luis_cordova
Hi @netacaduser
I found in your exercise two things you should keep in mind:
-Within the subinterfaces, with the encapsulation command dot1q <n°> you must indicate the number of vlan that will be associated with that subinterface.
encapsulation dot1Q 60 <-- for vlan 60
-To achieve the filter, you can use a standard acl.
I attached a compressed file with two versions of the exercise, one with full connectivity and the other with the filter using ACL(i use version 7.3.0 of PT).
Hi Luis,
Thank you for that! Completely missed that one, will make sure I change it!
