destination host unreachable
zachlin19381
Hello everyone
First of all, I buy 2 c3850-24t to stack them as core replacing my old 3650
the new core config the same with the old one
In the beginning, the new core work very well, but the client complains that they sometimes disconnect to our server
However, I use my PC ping my server, about every 30 minutes will show the reply from destination host unreachable much time
After that, work very normal...
Any direction I can troubleshooting?
Reza Sharifi
Look at the incoming and outgoing interfaces for drops, discord, retransmission, and any other error.
"sh int gigabit x/0/x"  should show you that.
 Only ping the internal device will happen. it works well through the firewall to internet
But the old core working well  confuse me
My edge switch very old like ten years old.
Is that possible to have compatibility problems?
No sure. Maybe you have some mismatch issues. Hard to tell without understanding your network, the devices you are using and the topology.
