Destination host unreachable
calvinshuen
Hello, I am a networking student and I am working on a project about VLAN.
My problem is VLAN 204 cannot ping VLAN 202 and VLAN 206. Any help please?
VLAN 202 Multimedia (Port F0/1-10) 192.168.202.0/24
VLAN 206 SalesMarketing (F0/11-15) 192.168.206.0/24
VLAN 204 IT Management (Port F0/16) 192.168.204.0/24
VLAN 999 Native
TotallyTodd
I totally didn't know how to find your dhcp pool but I totally tested it by statically configuring the default gateway onto the laptop and I was totally able to ping the host in the other subnets by changing the default gateway to 192.168.204.1 totally! Very cool lab by the way totally!
12 Replies 12
TotallyTodd
Totally need the password for the devices
Sorry I missed it. The password of console port is cisco. And enable secret is class. Thanks
emmaava7780
Following these steps you can easily fix it.
Select Settings > Network and Internet > Network Connections.
Right-click the relevant Local Area Network.
From the list, select Internet Protocol Version 6 (TCP/IPv6).
In the Properties tab, change the Default Gateway to the correct address.
Press OK to save the changes.
TotallyTodd
Your default gateway is totally set to 192.168.204.5 when it is supposed to be 192.168.204.1 totally! Totally More Successful Pings!
Thank I have change the IP address of my WIFI to 192.168.204.1 as the laptop's default gateway. I am OK to ping S1 and S2. But still cannot ping VLAN206 or VLAN202. It said destination host unreachable.
TotallyTodd
I set DHCP for VLAN 204 on WIFI GUI.
Here is my DHCP configure  for VLAN 202 and VLAN 206 on PER-R1.
ip dhcp excluded-address 192.168.202.1 192.168.202.99
ip dhcp excluded-address 192.168.206.1 192.168.206.99
ip dhcp excluded-address 192.168.202.151 192.168.202.254
ip dhcp excluded-address 192.168.206.151 192.168.206.255
ip dhcp pool VLAN_202_POOL_MM
network 192.168.202.0 255.255.255.0
dns-server 192.168.100.3
domain-name perth.mm.local
default-router 192.168.202.1
ip dhcp pool VLAN_206_POOL_SM
network 192.168.206.0 255.255.255.0
domain-name perth.sm.local
default-router 192.168.206.1
I'm totally looking at the instructions and I don't see any instruction to implement DHCP on that device totally. When I statically configured the laptop the pings worked totally! .
as far as I can see, the problem is that the wireless router has no Internet IP address. Is the wireless router a given, that is, is that device supposed to be there, or can you also use a wireless bridge (which I think is necessary for Vlan 204 to work and be routed on the PER-R1 router) ?
I have revised your topology and added a wireless access point (the management laptop now has a static IP address.
calvinshuen
The wireless router is given in this lab. I think there is some configuration problem in router PER-R1. The ping between VLAN 202 and 206 is all good. It seems Router drop the packet somewhere because of my poor configuration. Thanks for help.
calvinshuen
Thank guy. The problem was fixed. Thanks
