GUI not loading at WS-C3560X
I currently have the following problem. I'm in the process of setting up a test
environment and somehow the switch doesn't load the GUI even though I've
activated http and https in the config.
Do I have to do anything else so that it can load correctly with the GUI?
Here is the content of the FLASH memory:
Directory of flash:/
2 -rwx 1807 Apr 5 2023 10:06:49 +00:00 config.text
398 -rwx 1492 Apr 5 2023 10:06:49 +00:00 private-config.text
3 drwx 512 Apr 24 2018 16:27:08 +00:00 c3560e-universalk9-mz.152-4.E6
399 -rwx 6168 Apr 5 2023 10:06:49 +00:00 multiple-fs
395 drwx 512 Apr 24 2018 16:27:08 +00:00 dc_profile_dir
Here is another picture that my web browser shows me:
I would be happy if someone could help me so that I can use my test environment
completely. In order to then test settings before they are activated in the productive
network.
Best Regards
10 Replies 10
 First check this step and make sure you have all in place
create a user
==>1
username admintest privilege 15 privilege 15 secret admintest
then runn the http services
==>2
ip http server
ip http secure-server
ip http authentication login local
==>3
management ip
http://xx.x.x..xx.x.x
If you have all in place the problem is your browser. Try to use a different browser and make sure to use the browser in english language
marce1000
  - Make sure that when installing or downloading the software on the switch use or select distribution ...with web based  dev mgr  ,
 M.
unfortunately I can't download the latest IOS for the switch because Cisco
requires a service contract for it. And I don't have this, because the switch
was only made available to me so that I can build a test environment for
myself.
Is there perhaps the possibility of a TAC ticket that I can get the most
current IOS?
@Flavio Miranda: I have a user and HTTP settings, everything is running, otherwise
the web interface would not be displayed to me. It just doesn't load completely so
I can't do it there as can be seen in the picture. I've already tested 3 browsers
(Firefox, Edge and Chrome).
Best regards
 If you have no contract, no TAC
And the web interface display has nothing to see if username of course. Just trying to make sure all is good.
 Last but not least, make sure your browser is using english language. Maybe seens seilling but you can see here on the blog People reporting the solution by chaging browser language.
So it can't be because of the browsers, because I have web access to another
switch (live system), which then also works.
The settings are like the other switch in the config, I think it's probably the IOS,
but unfortunately I don't have a suitable web interface here which I could quickly
upload via TFTP.
Best regards
          - You can't  get software downloads through TAC      , only with service contract  ,
 M.
Leo Laohoo
Post the complete output to the command "dir flash:c3560e-universalk9-mz.152-4.E6/html".
Best regards
    7  -rwx        3500  Apr 24 2018 16:25:25 +00:00  ip.js
    8  -rwx      156176  Apr 24 2018 16:25:27 +00:00  dashboard.shtml
    9  -rwx         577  Apr 24 2018 16:25:28 +00:00  title.js
   10  drwx        1536  Nov 25 2020 17:44:52 +00:00  ja
   35  -rwx       19534  Apr 24 2018 16:25:31 +00:00  graph_dash.js
   36  -rwx       80863  Apr 24 2018 16:25:31 +00:00  portset.shtml
   37  -rwx        2228  Apr 24 2018 16:25:32 +00:00  gaaggrement.html
   38  -rwx        8976  Apr 24 2018 16:25:32 +00:00  xhome.htm
   39  -rwx       12467  Apr 24 2018 16:25:32 +00:00  sitewide.js
   40  drwx        2048  Nov 25 2020 17:47:07 +00:00  help2
   55  -rwx        6744  Apr 24 2018 16:25:34 +00:00  telnet.shtml
   56  -rwx       23522  Apr 24 2018 16:25:34 +00:00  toolbar.shtml
   57  -rwx          62  Apr 24 2018 16:25:34 +00:00  more.txt
   58  -rwx        6645  Apr 24 2018 16:25:34 +00:00  legend.htm
   59  -rwx       56470  Apr 24 2018 16:25:35 +00:00  monitordata.shtml
   60  -rwx        1018  Apr 24 2018 16:25:36 +00:00  redirect.htm
   61  drwx        2048  Nov 25 2020 17:47:19 +00:00  help
   79  -rwx        6825  Apr 24 2018 16:25:38 +00:00  express-setup.htm
   80  -rwx        7210  Apr 24 2018 16:25:38 +00:00  toolbar.js
   81  -rwx         950  Apr 24 2018 16:25:38 +00:00  frmwrkResource.htm
   82  -rwx         556  Apr 24 2018 16:25:38 +00:00  const.htm
   83  -rwx        3063  Apr 24 2018 16:25:38 +00:00  googleanalytics.js
   84  -rwx        8409  Apr 24 2018 16:25:38 +00:00  menu.shtml
   85  -rwx        1654  Apr 24 2018 16:25:39 +00:00  menu.css
   86  -rwx         846  Apr 24 2018 16:25:39 +00:00  reloadstatus.shtml
   87  -rwx         369  Apr 24 2018 16:25:39 +00:00  printframe.htm
   88  -rwx        1749  Apr 24 2018 16:25:39 +00:00  appsui.js
   89  -rwx       41550  Apr 24 2018 16:25:39 +00:00  topbanner.htm
   90  -rwx       48043  Apr 24 2018 16:25:40 +00:00  sorttable.js
   91  -rwx        9878  Apr 24 2018 16:25:40 +00:00  menu.js
   92  -rwx        8715  Apr 24 2018 16:25:40 +00:00  portstats.js
   93  -rwx         395  Apr 24 2018 16:25:40 +00:00  softwareupgradestatus.shtml
   94  -rwx        2016  Apr 24 2018 16:25:40 +00:00  softwareupgrade.htm
   95  -rwx       42576  Apr 24 2018 16:25:40 +00:00  discover.shtml
   96  -rwx       72439  Apr 24 2018 16:25:41 +00:00  jquery.js
   97  -rwx        4034  Apr 24 2018 16:25:41 +00:00  caa_upgrade.htm
   98  -rwx        9469  Apr 24 2018 16:25:41 +00:00  combo.js
   99  -rwx        2379  Apr 24 2018 16:25:41 +00:00  archivestatus.shtml
  100  -rwx        4829  Apr 24 2018 16:25:41 +00:00  converter.js
  101  -rwx      140805  Apr 24 2018 16:25:41 +00:00  discover.js
  102  -rwx       17383  Apr 24 2018 16:25:42 +00:00  preflight.js
  103  drwx        2048  Nov 25 2020 17:47:24 +00:00  help3
  121  -rwx       27224  Apr 24 2018 16:25:45 +00:00  stylesheet.css
  122  -rwx         471  Apr 24 2018 16:25:45 +00:00  homepage.htm
  123  -rwx       28354  Apr 24 2018 16:25:45 +00:00  ajax.js
  124  -rwx       71477  Apr 24 2018 16:25:45 +00:00  xsetup.js
  125  -rwx         425  Apr 24 2018 16:25:46 +00:00  reloadstatus.htm
  126  -rwx        1616  Apr 24 2018 16:25:46 +00:00  layers.js
  127  drwx        1536  Nov 25 2020 17:47:12 +00:00  en
  154  -rwx       13756  Apr 24 2018 16:25:49 +00:00  forms.js
  155  drwx       24576  Nov 25 2020 17:47:23 +00:00  images
  387  -rwx         515  Apr 24 2018 16:27:06 +00:00  back.htm
  388  -rwx      107812  Apr 24 2018 16:27:06 +00:00  xsetup.shtml
  389  -rwx       25401  Apr 24 2018 16:27:07 +00:00  framework.js
  390  -rwx        6501  Apr 24 2018 16:27:07 +00:00  reset.htm
  391  -rwx        7889  Apr 24 2018 16:27:07 +00:00  softwareupgrade-top.js
  392  -rwx       48034  Apr 24 2018 16:27:07 +00:00  portruntime.shtml
  393  -rwx       23346  Apr 24 2018 16:27:08 +00:00  topbannernofpv.shtml
  394  -rwx       21578  Apr 24 2018 16:27:08 +00:00  portstatistics.shtml
Find a machine with Windows 7 or use a very old browser.
I took a Windows 7 client and the problem remains. I think I have to
see that I can get an up-to-date IOS with a web interface in order
to be able to upload it to the switch.
Best regards
