Determine which port servers/clients are plugged into
8pcallahan
On a new Catalyst 6509 running IOS is there a way to tell which port a particular server or client is plugged into? (Without tracing patch cables)
I have done this on old switch gear with ARP and/or CAM tables. Does not appear to be the same on this new switch.
Thanks.
Jon Marshall
if you know the mac-address already
1) sh mac-address-table address "mac address"
If you need the IP address of the server first
1) sh arp | include "IP address".
from this you get the mac-address
2) as above.
Jon
Jon Marshall
2) as above.
Jon
Exactly what I needed! Thanks Jon!
Good, Yes it worked !!
Glad to be of help :-)
