device loopback IP went unreachable after 5 minutes when we are giving show logging command
sarathsivadasan
Device model :3850
Issue : device loopback IP went unreachable after 5 minutes when we are giving show logging command
We are trying to reach loopback ip address from outside but it is showing request timeout .
5 Replies 5
balaji.bandi
Can you please post show version and  show running configuration,Also tell us locally you can ping that time loopback ip?
BB
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.07.04.E.CES.16 ENGINEERING NOVA_WEEKLY BUILD, synced to V152_3_E4
This software is supported for a limited time under special agreement with Cisco Systems,Inc.CSG_OCT2016_BENI
Copyright (c) 1986-2016 by Cisco Systems, Inc.
sarathsivadasan
We are trying to reach loopback ip address from outside , same time we run the command "show logging " . During that time ping request fails to the loopback IP address.
If you are pinging normally it is working fine .
Do you have route for the Loopback for the external to reach ?, show us the configuration and from what is the source IP from  you try to reach to loopback ? can you traceroute from source IP for that loopback ip and post the output here
BB
Mark Elsen
 1) Can you provide sample output of 'show logging' indicatingyour conclusions ? 2) What is the value of this loopback address ?
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
